Coolant and oil mixed and low compression
41,000 MILES • 1.4L • 4 CYL • FWD • MANUAL
HIMANSHU SINGH
i have a Ford Figo 2012, 1.4 L duratorq TDCI. Recently found out a black gooey substance dripping down the front portion of the car. On opening the bonnet it was the coolant oozing out of the container. Took the car to a workshop and performed a compression test, the compression was low in two of the four alternating cylinders. What could be the possible explanation?
Sep 19, 2017 at 6:31 PM
STEVE W.
  • 15,418 POSTS
Sounds like a blown head gasket. There is a simple combustion gas test that can be done to confirm this. I would say you could look at the spark plug condition but as the shop removed them you will not know if they were put back into the same cylinders.
Sep 19, 2017 at 8:46 PM
ROBERT BOB JACKSON
Good day I have a ford figo tdci 2012 I found oil in the coolant bottle and no coolant in the oil what could be the problem
Jun 9, 2023 at 6:11 PM
  • 55,766 POSTS
I believe this engine has an oil cooler at the oil filter or close to it, this part is leaking internally into the radiator coolant. I would install a new cooler and flush the radiator and refill with new coolant.
Jun 10, 2023 at 3:20 AM
