connectors corrosion
106,000 MILES • 2.4L • 4 CYL • FWD • AUTOMATIC
ZEMORZEMOR
  • 486 POSTS
how to remove corrosion from computer connectors males and females? what product i can use?
Aug 27, 2017 at 12:28 PM
  • 31,937 POSTS
You can buy a terminal cleaner in a spray can, do not attempt to clean by hand as you can damage the pins, the spray cleaner will neutralize any corrosion and the conductive lubricant will help prevent further corrosion, also make sure that the rubber weather seal on the plug is in good condition, as for a brand i do not know what you have available, just ask your parts retailer or larger pars outlet and they should know.
Aug 28, 2017 at 4:27 PM
ZEMORZEMOR
  • 486 POSTS
thank you for your replay. i m asked you that question because i have a p1603 code and p0882 the transmission goes in limp in mode. last year took it to mechanic and said computer bad so i replaced same problem since than. from last year to now the p0882 is there and recently the p11603 showed up. in the winter time last year no codes ever in seems like those codes related to heat
Aug 28, 2017 at 11:42 PM
