Connecting rod bearing cap
80,000 MILES • 2.7L • 4 CYL • 2WD • MANUAL
MARK87
  • 61 POSTS
I'm in the process of assembling a Td27 engine and during the disassembled process I notice on the con rod cap there is an arrow, thing is the arrow for # 1, 2, and 4 is facing the rear of the engine and only #3 piston rod is facing forward. From my experience usually the arrows should be facing forward. Is it normal?or should a turn the con rod so that the arrow is facing forward?
Aug 30, 2020 at 5:21 AM
Good afternoon,
Did you replace the pistons?
Are the notches pointing forward to the front? The pistons may be on wrong.
Aug 30, 2020 at 5:38 AM
MARK87
  • 61 POSTS
I didn't replace the pistons. it's a longitudinal engine, the pistons combustion chamber is facing the injector side which should be the case.my guess is the connecting rod was wrongly put with the piston.Basically I tear down the engine to replace the big end bearing there was a knock, bearing was worn out.
Aug 30, 2020 at 4:38 PM
Can you post some pictures for me to view?
Aug 30, 2020 at 8:31 PM
MARK87
  • 61 POSTS
Sorry I don't have any pictures. I turn the connecting rod on the pistons so when I installed the con rod cap the arrow is facing forward to the timing gears. I could feel a difference in the engine when I started it after. from experience that I have for sure the pistons and connecting rod was installed incorrectly.
Sep 6, 2020 at 5:10 AM
Okay, feel a difference? What difference, good or bad?
Sep 6, 2020 at 5:13 AM
MARK87
  • 61 POSTS
A good difference, firstly it's starting better when engine is cold and better performance during hill climb..
Sep 6, 2020 at 4:16 PM
Good. I wanted to be sure it was better.
Sep 6, 2020 at 9:39 PM
