96 honda accord 2.2 L automatic front wheel drive not a VTEC
I did fuel pressure test and these are the result
- fuel pressure at idle and vacuum hose of the fuel pressure regulator connected 33Psi
- fuel pressure at idle and vacuum hose of the fuel pressure regulator disconnected 42 Psi
after that I turned off the engine the pressure was
at 4: 36 pm the pressure was 33 psi
at 4: 41 pm the pressure was 29 psi
at 4: 44 pm the pressure was 28 psi
at 4: 57 pm the pressure was 26 psi
at 5: 13 pm the pressure was 16 psi
at 5: 18 pm the pressure was 14 psi
at 5: 25 pm the pressure was 8 psi
at 5: 37 pm the pressure was 5 psi
the next day the pressure was 0 Psi
the fuel pressure regulator is good it does not let fuel goes back to the tank when the engine is off
and Hmac300 told everything is good. i did the fuel pressure test because the car long cranking when it seats for few hours
Jun 12, 2014 at 3:19 PM
