Cold weather hesitation
150,000 MILES • V8 • 2WD • AUTOMATIC
JMCMIC01
  • 13 POSTS
About 2 winters ago I noticed that my car would have random moments of what felt like the brake was applied momentarily and hesitate when driving on the expressway. This happens every winter and the only pattern I see is that it is below 40 and I am traveling above 65 mph. I never have this problem otherwise. When I continue to drive at the higher speeds the hesitations become more frequent and severe, if I slow down to 63, 62 mph it stops.
Jan 25, 2019 at 2:57 AM
Good afternoon
Is the check engine light on? I would like to see if the PCM sees something wrong.
There are some possibilities.
1. Fuel injectors. I would have them professionally cleaned as additives have no effect on cleaning.
https://www.2carpros.com/articles/how-fuel-injection-systems-work
2. Check the cat converter from being clogged.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
How long since changing the plugs and filters?
Jan 25, 2019 at 3:29 AM
JMCMIC01
  • 13 POSTS
Ugh. I am embarrassed to say that plugs and filters haven't been changed since I have owned the car (purchased in 2013) but for things included in oul changes. The check engine light is also on due to an emissions pump that needs to be replaced and I haven't been able to prioritize. There are multiple msgs when scanned but they are pretty vague and don't know what they are offhand. So the fuel injectors and catalytic converter being clogged could be made worse by cold temps?
Jan 25, 2019 at 5:01 AM
Yes, but I would start with basics like you plugs and filters.
Jan 25, 2019 at 5:07 AM
