Cold start problem?
2001 ROVER 45
54,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
MARTIN RAFKO
I've been having an issue with my vehicle ever since I returned from holiday. When trying to start cold the engine struggles to turn the motor over, it chokes immediately and shakes a little bit.
Before it wouldn't start the first time, but when I tried the second time it fired right up. Now it's just choking, shaking, and struggling to start up even after three tries.
The car is running fine once it started, when warm it start straight up like before.
I've replaced the battery, fuel pump and coolant temperature sensor. None of that helped.
Any thoughts where the problem could be? Fuel system seems fine.
Cheers
Nov 5, 2022 at 7:56 PM
  • 110,241 POSTS
This model isn't offered in the US, but I will try my best to help.
I want you to try something and let me know the results. Follow these directions and let me know the results.
1) Turn the key from the off to the run position (engine off) and count to 5.
2) Repeat step 1 a total of 5 times.
3) On the 6th cycle, see if it starts normally.
Let me know the results.
Nov 6, 2022 at 1:02 PM
MARTIN RAFKO
Hi Joe,
I tried it but it did not help.
Was thinking if car is chocking when starting could the problem be in throttle body or sparks/injectors? Cheers
Nov 8, 2022 at 12:32 AM
  • 110,241 POSTS
It could be the result of a few things. For example, the fuel pressure may be too low or too high. Also, the engine coolant temperature sensor may be faulty.
The engine coolant temp sensor on many vehicles is used by the PCM to determine the air/fuel mixture based on temperature. If it is very cold, the fuel mixture is richer and the opposite.
Here is what I suggest. If you have a live data scan tool, before starting the vehicle in the morning, see if the temperature sensor's signal is near the outside ambient temperature. Also, when it does finally start, see if there is any smoke from the exhaust. Since you mentioned it feels/sounds flooded, see if there is any dark gray or black smoke from the exhaust when you start it.
If you don't have a scanner to do this, I would suggest checking the fuel pressure.
Here is a link that explains in general how it's done:
Let me know what you find.
Nov 8, 2022 at 11:00 AM
