Heater blowing cold air
2001 VOLKSWAGEN GOLF
162,000 MILES • 1.9L • TURBO • 2WD • MANUAL
AUBZ44
Hi, I have a mk4 golf GT tdi pd 130. the heaters are blowing cold air through. I changed the thermostat but not the sensor. I topped up with new coolant. was just wondering if I do a full coolant system flush including the radiator if this will solve the problem?
Dec 6, 2020 at 5:06 PM
I suspect this is a blend door actuator issue and not necessarily a coolant issue. It could be a heater core but I would start with the actuator and make sure that is functioning properly first.
Here are guides that will help with this:
https://www.2carpros.com/articles/car-heater-not-working
Then if the heater core is still an issue, you will not be able to flush it. These are called multipassage units which means if there is a restriction or a blockage it will just find another path and not remove the blockage. If that is the issue then you will have to replace it. However, I doubt that is the cause so let's check this first.
Let me know what questions you have. Thanks
Dec 7, 2020 at 12:31 AM
