I have a 2003 Ford F-150 (4.2L V6, Manual Trans) that's been running poorly for a while, both when idling and at speed. The engine vibrates, more so when accelerating, possibly indicating a misfire. The computer has thrown codes for the Bank 2 O2 Sensor 1, Crankshaft Position Sensor, Mass Airflow Sensor, and indicated a possible Fuel Injector problem. I have consequently replaced the injectors, cs pos sensor, mass airflow sensor, the indicated O2 sensor, and sparkplugs. I also cleaned my aftermarket cold air intake, checked for vacuum leaks, and changed my fuel filter. My next course of action I believe will be to test fuel pressure, and ensure proper functionality of the coil packs. If you have any suggestions or have heard of similar problems with these trucks in the past, your help would be greatly appreciated. Thanks a lot for your time.
Michael Pace
michaelbpace@yahoo.com
Dec 15, 2020 at 7:29 AM
(Merged)
