HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Engine
Throttle Body
Throttle Position Sensor
Replace/Remove
SPONSORED LINKS
Codes after throttle position sensor change
PREV
1
2
NEXT
MECHANIC
Yes, like I said before, the TPS had nothing to do with the rough running.
Glad to hear you are running.
Friday, April 2nd, 2021 AT 12:10 PM
PREV
1
2
NEXT
Please
login
or
register
to post a reply.
Related Throttle Position Sensor Replace/Remove Content
Throttle Position Sensor Location
So My Truck Has Been Acting Weird The Last Couple Of Months, I Had The Maf Changed Out And It Still Coding, P2106 Is The Code. Really Hope...
Asked by
jake_f150
1 ANSWER
7 IMAGES
2004
FORD F-150
1997 Ford F150 1997 F150
Okay, So My Truck Has A Few Problems, The Truck Runs And Fine And Has Tons Of Power But My Check Engine Light Is On, It Reads Throttle...
Asked by
joelnaumann
1997
FORD F-150
1992 Ford F-150 Throttle Position Sensor
I Took My 92 Ford F-150 To Tires Plus To Fix Brakes And Because It Idles High. They Said It Was The Throttle Air Bypass And Replaced The...
Asked by
Mblake1
1992
FORD F-150
Does My Tps Need Adjusting
Just Replaced My Tps, And Now The Truck Wont Start (unless Using Ether)then It Idles High. Does The Sensor Need Adjusting (if So How Do I Do...
Asked by
tsandridge
1 ANSWER
1992
FORD F-150
1992 Ford F150 Tp Sensor
I Was Wondering Where The Tp Sensor Is Located On The Throttle Body, And If Any Tools Are Required To Mount It Properly.
Asked by
tjohnson62988
1 ANSWER
1992
FORD F-150
VIEW MORE
SPONSORED LINKS
Code Read Retrieval/Clear Scion
How to Read Trouble Codes
Topdon OBD2 Scanner Review - This thing rocks
Online car repair manuals
