Engine missing and backfiring
SCOTTB10
  • 36 POSTS
I was crawling around the car today and I found a fuse panel up under the passenger side dash. Of course it's not in my book or could I find it online so I just started pulling fuses. The second one was one of those little red 10 amps and it was burnt out so I replaced it and the car started right up. So that's out of the way. Now for the mass air flow or whatever it is.I took it to the only shop we have in Happy Camp and Al looked at it and said he'd never seen anything like it but he said since it has a spring in it he thought it was the PCV, Any way I'm taking it to him in the morning and he's going to put the OB1 on it and see if he can figure out what's wrong. I will let you know what comes of it. He's the one that originally coded it for me 2 month's ago and hasn't done anything for it since. So I don't hold my breath. I told him I can fix it if he just test's it and tells me what's wrong. I figure 50/50 chance. I'll let you know.
Tuesday, May 19th, 2020 AT 7:54 PM
SCOTTB10
  • 36 POSTS
I don't know if I told you but I was at Al's shop last Friday trying to get him to test the car, but he told me to come back the next day. Well when I went to leave the battery was dead, so Al brought out this huge yellow jumper box and gave the car a zap. I mean that car started right away, The zap was very powerful, I could feel it when it cranked it must have been a 50 amp jolt. So I drove home and and that's when it wouldn't start anymore, I think his jumper fried that fuse.
Tuesday, May 19th, 2020 AT 8:02 PM
That could make sense about the no start and the fuse. I am not sure a PCV would have 3 bolts in it so I am curious to see it if you can snap a picture of it, that would be great. Thanks
Wednesday, May 20th, 2020 AT 7:18 PM
SCOTTB10
  • 36 POSTS
Here's an update Kenny:
We were checking the spark and a couple cylinder were weak. So I thought it was the plug wires. So I drove 150 miles to Yreka and got a set of wires. But when I put them on it didn't make much difference. I started pulling the wires of from the coil pack 1 by 1 and the pack I have has 3 coils. Each one does 2 cylinders. Well the bottom coil was the weak one, I had to order it online. I'm supposed to get it tomorrow. I've got my fingers crossed. I'll let you know.
Thursday, May 21st, 2020 AT 8:18 PM
Great. As I was reading through it I was hoping you were going to check the coils for a weak spark. I am going to assume that you got it once you replace it.
Let us know and we can go from there. Thanks
Friday, May 22nd, 2020 AT 7:42 PM
SCOTTB10
  • 36 POSTS
New coils, Still not much difference. Starts missing as soon as it goes under a load.
Saturday, May 23rd, 2020 AT 9:25 AM
In reviewing this entire post, I didn't see any fuel pressure readings. If this is a misfire under load, we need to check fuel pressure. I am thinking we may have a fuel delivery issue but let's start with what the pressure is when this is misfiring.
Also, do you have a scan tool that you can look at o2 sensor data from the PCM?
Saturday, May 23rd, 2020 AT 8:42 PM
SCOTTB10
  • 36 POSTS
Tomorrow it goes into the shop for more testing.
Sunday, May 24th, 2020 AT 9:26 AM
Okay. Great. Let us know what happens because this one has me curious. Thanks for the update.
Sunday, May 24th, 2020 AT 7:56 PM
SCOTTB10
  • 36 POSTS
Running like a dream. Turned out to be the middle sparkplug in the back.
Tuesday, May 26th, 2020 AT 8:24 PM
Great update. Thanks for letting us know what it was. Glad you got it figured out. Come back next time and thanks for using 2CarPros.
Wednesday, May 27th, 2020 AT 7:23 PM
SCOTTB10
  • 36 POSTS
The thanks goes to you Kenny, You very patiently guided me along and I needed that. Thanks for all your help. Let me tell you where I'm at now. Al my mechanic friend told me to take the battery terminals off and touch them together to clear the check engine code. Well I did that, but what is amazing is I put the positive terminal back on the battery and then started on the negative. While putting on the negative the engine started cranking, But I had the key's in my pocket so I thought at least it won't start, but oh yea. It started. I put the key in the ignition and turned it on but nothing happened, It kept running, I turned it to the off position and it kept running. Then I put my foot on the brake and it stopped. So I tried to start it with the key and it worked. It also didn't clear the code. I've changed a lot of batteries in my time, But I've never had one start while doing it. Maybe this has something to do with the battery dying. The mystery continues?
Thursday, May 28th, 2020 AT 9:34 AM
Thank you for the kind words. However, you did the work so the credit is all yours.
As for this issue I suspect we have an ignition switch issue but it is very odd that it just started out of nowhere, unless you have had issue with the ignition switch in the past.
We can dig into this but unfortunately we have to get a new post started. The only reason is, others will not find the solution to it starting on its own under this heading. Not only are we here to help you but hopefully as we help you solve these issues, others can read them if they are dealing with the same thing.
If you don't mind starting a new post, I will look for it and jump on it or one of our other experts will grab it. Either way, I am sure we will get that figured out. If you don't mind including whether it is starting normally now after it shut off or what it does when you try to start it.
Sorry for any inconvenience. Thanks
Friday, May 29th, 2020 AT 5:08 PM
