Clutch slave cylinder and master cylinder
1995 ISUZU TROOPER
250,000 MILES • 4WD • MANUAL
BRITT TORRES
I have replaced the clutch slave and master because my clutch pedal got stuck to the floor. I have bled it and it still isn’t giving enough pressure.
Nov 18, 2020 at 6:55 AM
Does the pedal still stick to the floor or are you able to pump it now but it just doesn't build pressure?
I am thinking we have an issue with the throw out bearing as well. However, we need to start with making sure when you bleed the system that you are not getting air. If you are getting solid fluid then that is where we need to start.
Here is a guide talking about the throw out bearing:
https://www.2carpros.com/articles/throw-out-bearing-replacement
Then here is a link that helps with the basic things we are going to go through. Let's run through this info and go from there.
https://www.2carpros.com/articles/clutch-doesnt-work-sometimes-or-not-at-all
Thanks
Nov 20, 2020 at 7:39 AM
