1989 Isuzu Trooper clutch problems
165,000 MILES • 6 CYL • 4WD • MANUAL
CHRIS MAJOR
I have replaced the clutch and all parts. then I replaced the slave cylinder and bleed the system until all air is gone but the clutch still lets the trans engage with it pressed down to the floor. there is a junction box between the master and slave. no one can tell me what it is. all the repair manauls show nothing. can you tell me what that box does.
Mar 28, 2008 at 4:17 PM
  • 75,988 POSTS
I've been looking for it in the software I'm using and there's nothing in between the clutch master cylinder and the clutch slave/servo-Does it have hydraulic lines coming from the clutch master cylinder and to the slave?
Mar 29, 2008 at 12:34 AM
