Clutch stopped working
100,000 MILES • 5.9L • 6 CYL • TURBO • 4WD • MANUAL
JESSE BOWSER
Clutch stopped working at a stop sign then started working for a day, lots of stop and go then went out again. No smell no noise I replaced master and slave bled lines the hydraulic system seems to be working correctly. So I used a C clamp and put it on the clutch fork and clamped as far as it would go and my truck still will not go in gear. is this a throw out bearing or disk issue? I can shift with no clutch no slipping just cannot put it in gear.
Dec 20, 2017 at 11:22 PM
  • 55,711 POSTS
Is sounds like you have a clutch that is falling apart which will not allow the clutch to disengage.
Here are guides to help you see what I am talking about:
https://www.2carpros.com/articles/clutch-doesnt-work-sometimes-or-not-at-all
and
https://www.2carpros.com/articles/how-to-replace-a-clutch
Cheers, Ken
Dec 22, 2017 at 9:10 AM
