Cluster swap
169,401 MILES • 5.8L • V8 • 2WD • AUTOMATIC
TVSMAPLES
I swapped my broken "literally" broken beat to heck 2003 cluster and put a 2002 Chevrolet Tahoe cluster in both 2wd and it didn't work and my door switches lights and locks are going crazy now. is it compatible? if so what do i do to make it work? does it need to be programmed?
Dec 13, 2019 at 1:00 PM
  • 110,248 POSTS
It sounds like you have a different cluster. Did you confirm that the part numbers were the same? Also, there really isn't a relearn for the cluster.
Dec 13, 2019 at 1:13 PM
