clunk at the end of shifting
176,000 MILES • V8 • 2WD • AUTOMATIC
NASER NASER
  • 836 POSTS
which is more common a transmission mount, rear end or a driveshaft failure that can cause a clunk by the end of the shifting, going for example first to second by the time she shifts it clunks. I know it's a mount or a joint issue and not a transmission issue, had my shares, but on this dodge it does it randomly, shifting is smooth.
Mar 8, 2020 at 10:14 AM
  • 110,248 POSTS
Have you checked universal joints? Also, have you checked to see if there is excessive play in the pinion shaft? As far as a mount, I would think you would hear it when you shift between reverse and drive. Is it only when it shifts?
https://www.2carpros.com/articles/how-u-joints-work
Also, check to make sure the differential fluid is full and there is no evidence of shavings in the fluid.
https://www.2carpros.com/articles/differential-gear-oil-fluid-check
One last thought. Open the hood and watch the engine as you shift between drive and reverse to make sure nothing is broken as far as a motor mount.
Let me know what you find.
Mar 8, 2020 at 11:44 AM
