Accelerating issue
168,043 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
JIMMYORTIZ
If the clock spring is bad would that cause the car not to accelerate?
Jan 21, 2020 at 9:31 AM
Normally not. This is just to keep connection between the airbag, steering wheel controls, and horn to the rest of the electrical system. If you have an acceleration issue we need the detail on when this happens or if it goes away at certain speeds. Also, does it do this all the time? We need to find out if there are codes also.
https://www.2carpros.com/articles/symptoms-of-a-bad-airbag-clock-spring
Jan 21, 2020 at 10:13 AM
  • 55,721 POSTS
It sounds like the car maybe in limp mode due to a dirty throttle actuator. here is a guide to help fix it:
Jan 21, 2020 at 12:03 PM
