Hello
Thanks for the donation
It sounds like you may have a vacuum leak. Check under the hood for a disconnected or damaged vacuum line. The controls are vacuum operated and if the vacuum supply is cut off the system defaults to defroster only. Some vacuum lines may also be located inside of dash.
Hope this helps.
Thanks for using 2carpros. Com!
Wednesday, March 13th, 2019 AT 5:38 PM
(Merged)
