I was wondering what to cover under my hood, if I was to pressure wash the truck motor to clean it up. Thank you very much!
Sep 4, 2018 at 9:59 AM
✓Experienced Mechanic
Ideally, you do not want to direct high pressure around any electrical connections as these are the weak link in the system so to speak. Give the engine a wash down with degreaser or engine wash, let it soften the grime and was down with a hose, a high pressure was can force water under the seals of the electrical plugs, this is what you want to avoid.
