Suddenly the vehicle will not start?
120,000 MILES • 5.9L • V8 • 4WD • MANUAL
CJ71986
Ran vehicle to the store when I came out my vehicle wouldn't start. Battery had a good volt reading on the gauge bit when I went to position 4 to turn over the motor, my battery gauge went right to 0v. I've replaced the starter, solenoid and have good cables
on all the grounds and positive as well. I do hear the solenoid engaging. I've tried starting with starter disconnected Ted and battery gauge drops but it doesn't stay drained. When I have the alternator and starter hooked up it goes drained and I have to disconnect the battery positive and reconnect it to try starting it again. Would love some advice if you can think of anything. thanks
Jul 29, 2022 at 1:16 PM
  • 55,732 POSTS
This sounds like the battery is no good. To be sure let's do a load test.
Here is a guide that will help confirm the issue:
And if bad this guide can walk you through the replacement:
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Jul 30, 2022 at 8:53 AM
