1990 Chrysler Van water pump
TAMMYSOCAL
Engine Cooling problem
1990 Chrysler Van 6 cyl Front Wheel Drive Automatic
Just had radiator & therostat replaced. Now coolant is not circulating. What should I check or do next to fix this problem?
Nov 3, 2008 at 8:10 AM
  • 110,248 POSTS
Hi:
Is the engine overheating? Also, if the radiator is new, and the waterpump belt is working and spining the pump, either the new t-stat isn't opening or you have a rad hose pinching shut. Check the hoses when the car starts to get hot. Also, if you decide to remove the t-stat again, place it in a pot of boiling water to see if it opens.
Let me know what you find.
Nov 8, 2008 at 9:57 AM
