2002 Chrysler Town and Country No Dash Lights Fix
This is very strange, but this last Sunday driving back from Chicago, our Town and Country minivan's dash lights also failed - all of them. Can't see the speed, fuel status, etc.
We just took it to our usually trustworthy local garage and they said - two weeks at the dealership and $1200 will fix the problem. They thought it was the instrument cluster.
Coincidently, the minivan has the original battery in it - they recommended a replacement today which we agreed to, and the lights now work. Apparently, the battery just wasn't putting out enough juice and things started shutting down. Obviously, we'd rather have the dash lights go out rather than some other essential service.
Good luck!
-Michael
Suggested Repair
If the other dash lights work and no fuses are blown, the speedometer and tachometer illumination may need a new bulb. Removing the instrument cluster is required, and all cluster bulbs should be replaced while it is out. A later report also said a weak original battery caused all dash lights to fail and that replacing the battery restored them.
Conversation Summary
A 2002 Chrysler Town and Country with 106,000 miles had a dead battery after sitting, possibly with a light left on. After charging, it started and everything worked except the lighting around the speedometer and tachometer, and no blown fuses were found. The expert said a bulb may be needed and recommended replacing all bulbs while the instrument cluster is removed. Another owner reported all dash lights failing and a shop quoting an instrument cluster repair, but said replacing the original weak battery restored the lights.
