2005 Chrysler Town and Country dash lights ---sliding doors
2005 CHRYSLER TOWN AND COUNTRY
67,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOHN L
Turned on ignition switch , no dash lights -no turn signals - no brake lights except light on lift gate-
radio-heater controls illuminated and working normal--
cruise control normal--hi and low beam work but no
illumination on dash -- BEFORE-- this problem neither
sliding door would operate using inside passenger
switch-- but -- doors operated normal using remote
or overhead panel switch--child safety switch in open
position.
At the same time as the 'no dash light problem' at
35 to 45mph [approx] the car feels like it is trying
to go into gear, you feel a back and forth or in and
out feeling , slight but my passenger felt it. This
is not felt at highway speed or with cruise on.
Oct 29, 2010 at 4:53 AM
SERVICE WRITER
  • 9,123 POSTS
This sound like a problem with a module not communicating. This has CAN-controller are network in which the modules "talk to each other. This may be a component or wiring issue.
You will need a scanner that works with CAN to diagnose this. Need to get the codes...
Areas to consider checking otherwise are under that battery tray for corrosion on wiring, ignition switch, bad ground.
Oct 30, 2010 at 1:53 AM
