2005 Chrysler Town and Country Noisy Steering
2005 CHRYSLER TOWN AND COUNTRY
SCRPRKIM
Steering problem
2005 Chrysler Town and Country Front Wheel Drive
My T&C has begun making a terrible noise when steering wheel goes to the left. It happens when turning and on the return from a turn to the right. It happened one time last year with extreme cold and ice. It began again several weeks ago as the outdoor temperature began to drop again, but it is much more consistent. The power steering fluid levels are fine. Please help.
KIM
Dec 7, 2009 at 11:49 PM
  • 110,240 POSTS
Kim:
Chances are the pump is going bad. You can try having it serviced to see if that helps. If it doesn't help, you may need to replace the pump.
Let me know if the service helps.
Dec 21, 2009 at 11:52 PM
