2003 Chrysler Town and Country van pulls to left
60,000 MILES • 6 CYL • 2WD • AUTOMATIC
SMITHGLAZE
i took the van to the dealer for alignment but they said one tire a little more tread wear then the other so they couldn't set the toe in.tires only had 4000 miles on them so i said to do best they can.their read out sheet showed changes they made. car drives same as it was. every time i've taken a car for alignment they can never do it with out 5 or 6 hundred dollars in repairs.my question is, will 1/32 nd more tread wear on one tire keep toe in from being set well enough to stop the van from pulling to left.(front wheels)
Jan 17, 2009 at 10:21 AM
  • 110,248 POSTS
Hi:
You can set tow under those conditions. It's common for the right tire to wear faster than the left because it's the drive wheel. (was I correct to say the right tire is the one with less tread?)
Jan 18, 2009 at 11:21 AM
