2005 Chrysler Town and Country door locks
STONEKILL007
  • 2005 CHRYSLER TOWN AND COUNTRY
All my door locks are not working, I checked the fuse box in the engine compartment to no avail, because it doesn't specify which fuse it is pertaining to door locks. I read another answer in your forum that says there's another fuse box in the driver side dash, but where exactly because I can't find it.
Monday, July 26th, 2010 AT 6:15 AM
  • 109,885 POSTS
It should be under the dash on the driver's side. You may have to remove a panel to access it.
As far as the locks, the easiest thing to do is check if there is power to the main switch on the driver's door. If there is, then either there is a relay problem or that main switch is bad.
Monday, July 26th, 2010 AT 9:23 PM
