2005 Chrysler Town and Country Door Locks
BREWER32
  • 2005 CHRYSLER TOWN AND COUNTRY
  • 6 CYL
  • 110,000 MILES
My door locks do not open or close from the any of the door lock switches nor do they work from my remote. I cannot locate the fuse to check and see if it is burned out. It stopped working the worked and now it has stopped working again.
Saturday, July 10th, 2010 AT 4:10 PM
  • 109,885 POSTS
Hi:
First, there should be a fuse under both under the dash and the hood. check them, but honestly, since the problem has come and gone, chances are the fuse isn't the problem. My first thought is a bad main switch on the driver's door. Check it to make sure it is getting power. It should have 12 volts all the time and only actuate the lock solenoid when the button is pushed. If there is 12 volts to it, make sure power is coming out of the switch when you push the button. If it isn't replace the switch.
Here is a how to for checking the actual locking solenoids. Again, I doubt they all went bad at the same time, but it does offer the directions for removal and checking.
https://www.2carpros.com/how_to/door_lock.htm
Let me know if this helps you.
Friday, July 16th, 2010 AT 10:42 PM
