2002 Chrysler Town and Country
DADS10
2002 Chrysler Town and Country 6 cyl Two Wheel Drive Automatic
2002 Chrysler town and country, 3.3 6 cylinder. How to remove a key cylinder when frozen. Will not turn, to enable you to push in retaining tab.
Nov 15, 2009 at 8:19 AM
KNOWYOURAUTO
  • 113 POSTS
Hopefully the cylinder is just dry not broken. You can pick up a special lube for the lock cylinder by checking around. May be at a locksmith shop, possibly parts store. Though it will be difficult to spray inside with key in the way, just keep a towel under it, give it a little time to work.
We have freed up many keys using this method.
Good Luck,
Nov 16, 2009 at 1:57 AM
