2001 Chrysler Town and Country 2001 Chrysler T&C: Trans
128,000 MILES • 6 CYL • AWD • AUTOMATIC
BARONHAWK
My tranny seems to work fine. It's stuck in second gear. The speedometer works fine. Cruise works fine. Other electrical problems are the pass. side window not working. Drvr side window is intermittent, and the blower is on high all the time, even when shutting of the air.
I took it to a Chrysler specialist. He said the computer is reading 0 degrees from the tranny. He believes it's a connection to the Transmission Control Module is either shorted or open.
I am looking for a schematic of the TCM and where it's located in the engine compartment. Possible around the battery.
Please help. I need to troubleshoot and fix this asap.
Thanks for your time
Kevin Schraeder
baronhawk@comcast.net
Jun 19, 2009 at 3:28 AM
MERLIN2021
  • 17,250 POSTS
TCM is located behind the inner fender well of the driver side wheel. It also has a very high failure rate due to corrosion because of its location. Chryslers better idea...
If you need the wiring diagram I will look for it, but check the condition of the mod and wires first!
Jun 20, 2009 at 1:04 AM
