1998 Chrysler Town and Country wipers stay on
1998 CHRYSLER TOWN AND COUNTRY
166,000 MILES • 6 CYL • FWD • AUTOMATIC
CADDY CRAZY
i have a 98 town & country, the wipers come on and stay on as soon as you start the van, i have replaced the multi switch at the steering wheel, and still does it, i also disconected the multi switch and they still come on, replaced both moduals and that didnt help, something is keeping the low speed on can you help thanks
Jul 5, 2010 at 1:01 PM
RICHZOMBIE
  • 173 POSTS
your wiper high/low relay or the wiper on relay may be sticking / faulty. they are both located in the power distribution center (left side of engine compartment).
Jul 5, 2010 at 1:39 PM
CADDY CRAZY
replaced both relays and now it comes on every 15 seconds, even with the multi function disconeted,,
Jul 6, 2010 at 12:32 AM
RICHZOMBIE
  • 173 POSTS
disconnecting the switch only proves its not the switch at fault..
since relays are known-good and you replaced module already then the wiper motor and circuit board (part of motor) must have closed circuit allowing wipers to run without switch on.
Jul 6, 2010 at 3:06 PM
