1997 Chrysler Town and Country Drecreasing Gas mileage lead
CURLY_C
  • 1997 CHRYSLER TOWN AND COUNTRY
  • 6 CYL
  • AWD
  • 240,935 MILES
The EGR valve was recently replaced on this vehicle along with the throttle body. That was about a week ago. Yesterday I took the van to Valvoline and had the oil changed, the transmission fluid changed along with the power train and the rear differential. The van ran fine following this. We stopped and put gas in, went to visit a friend and when I left there the van wanted to stall or run rough when I would stop. I got the vehicle home, and it was getting about 11 miles per gallon. I went out later to take it for a drive, after adding additives to remove any water in the fuel. There is no spark. Please help me with this, I need to get back to work tomorrow. Thanks, Cecelia
Monday, March 8th, 2010 AT 8:07 AM
  • 109,885 POSTS
If you are not getting spark, have you checked to see if you have power to the coil?
Saturday, March 13th, 2010 AT 10:48 PM
CURLY_C
The van is in the shop now. They checked the fuel pump, it works. The crank shaft sensor was out. Still no spark. Got readings all the way back to the computer, but no response from the computer. Tried the computer, no spark. Was suggested from another site to try the Auto Shut Down Relay and Fuse. They are trying that today. No idea what to do next.
Monday, March 15th, 2010 AT 12:55 PM
  • 109,885 POSTS
Have you tried a different computer?
Monday, March 15th, 2010 AT 1:17 PM
CURLY_C
They have reprogrammed the computer with no luck. They have determined that it is not the engine computer. They want to reprogram the body computer. Do you think it could be the security system? The thing I fear is a broken wire. I have started car shopping.
Saturday, March 20th, 2010 AT 8:26 PM
  • 109,885 POSTS
It could be the body control module. It is responsible for many things. Let them check that.
Sunday, March 21st, 2010 AT 12:45 AM
