1998 Chrysler Sebring No Crank
YEAHKID
when trying to start my 1998 chrysler sebring convertible I get no crank and oly the dash brakelight and odometer lights up. What could be the problem?
May 3, 2007 at 3:23 AM
BACKYARDMECHANIC
  • 337 POSTS
The car not cranking can be caused by a few things.
1) The battery. Is it fully charged?
2) The battery cables. Are they clean and tight?
3) The starter. Could be defective or have a open wire feeding it.
4) A fuse. Check all fuses make sure they are good.
Check all of the above and you should find your cause for the car not cranking.
May 3, 2007 at 6:46 AM
Suggested Repair
Check that the battery is fully charged and the cables are clean and tight. Inspect the starter and its feed wire, and verify that all fuses are good.
Conversation Summary
The owner of a 1998 Chrysler Sebring convertible reports no crank, with only the dash brake light and odometer lighting. The expert says the cause may be a weak battery, poor battery cables, a defective starter or open starter wire, or a bad fuse, and recommends checking each.
