2001 Chrysler Sebring Won't Start, Just Clicks
BSHORTRI
  • 2001 CHRYSLER SEBRING
  • 6 CYL
  • FWD
  • 100,000 MILES
When I turn the key, I get a rapid clicking and the car won't start. The radio and fan will come on unless I turn the lights on, which then kicks the radio and fan off. Any suggestions as to what might be the cause?
Sunday, February 21st, 2010 AT 2:15 PM
CARADIODOC
  • 33,881 POSTS
Battery is run down or the cable connections are loose or dirty. Try charging the battery for half an hour on the lowest setting. Charging an older battery at a real fast rate will shorten the battery's life due to vibrating the plates which accelerates the rate at which the lead flakes off.
Once the engine is running, check the charging system with a digital voltmeter. Measure the voltage between the two battery terminals. It must be between 13.75 and 14.75 volts. If it stays around 12.0 volts, the charging system is not working. If it is within the acceptable range, either something was left on that ran the battery down, or it might just be time for a new battery. If you find the voltage is well above 15.0 volts, the system is overcharging the battery. Water will boil out ruining the battery.
Caradiodoc
Sunday, February 21st, 2010 AT 5:20 PM
BSHORTRI
Thank you caradiodoc
Monday, February 22nd, 2010 AT 9:12 AM
