2000 Chrysler Sebring stalling
LONGLEANLADY
  • 2000 CHRYSLER SEBRING
  • 6 CYL
  • FWD
  • 123,800 MILES
I really need help. My sebring was stalling while I was drivng. All of this started about 3 months ago.
since then ive replaced my timing belt, fuel filter, spark plugs, wires, rotors and crankshaft sensor(2times).
it has also developed a leak in the flex pipe.
my ses light does not come on.
i took it to midas and they sprayed a cleaner in the throttle body.
it stopped stalling for about 4 days.
today I started driving and it cut out, only this time I almost didnt get it started.
my mechanic cant figure it out.
any suggestions?
Wednesday, May 14th, 2008 AT 2:28 PM
BMRFIXIT
  • 19,053 POSTS
Check EGR valve and its operation
check idle air control valve ensure it clean and functioning to spec.
Sunday, May 18th, 2008 AT 6:23 AM
JRHARKINS
Hey - did you ever get an answer to your stalling problems. The exact same thing has been happing to me, and I was about to get the timing belt changed, if that is not gonna do the trick I would love to know. If you got an answer to your issue let me know.
Thanks
jeff
Monday, June 23rd, 2008 AT 9:45 AM
BMRFIXIT
  • 19,053 POSTS
Is stalling and will not start until it cool off and or you have to wait for restart
and if so check and or replace the crank sensor and its wiring
Have an automotive repair question!
Sign up and ask your automotive question !
Monday, June 23rd, 2008 AT 8:30 PM
