2000 Chrysler Sebring Car stalling when driving...
ROMMIE
Engine Mechanical problem
2000 Chrysler Sebring 6 cyl Front Wheel Drive Automatic
When driving on level ground with cruise control set at 60, the engine dies, I am able to put the car into nuetral without coming to a stop and restarting the engine.This has happened four times, twice,while I was driving and another two times while I was stopped. When I was stopped it took as long as ten minutes to start the car. We have taken it into the Chrysler dealer, they found no error codes, yet on the way home as we slowed down to come into the driveway it stalled again. Started up within ten minutes. What could be the problem?
Feb 15, 2010 at 7:47 AM
  • 110,251 POSTS
It could be many things. The fact there is no check engine light coming on and no codes makes it tough to pinpoint. I would recommend checking for vacuum leaks and fuel pump pressure. Here is a how to for checking pressure:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find.
Feb 15, 2010 at 2:58 PM
