2000 Chrysler Sebring intermittent engine stalling
201,000 MILES • 6 CYL • FWD • AUTOMATIC
MISTERENERGY
I just purchased a 2000 Sebring JXI convertable with 201,000 miles on it last Wednesday. On Friday, after the car had been sitting in a parking lot for about 2 hours (outside temp was about 95 degrees and low humidity). The car started fine and I drove about 300 yards and the engine cut out. I let it set for about 45 seconds and it started up. I drove it another 400 yards and it stalled again. This time it did not retart for about 5 minutes. I towed it to a parking lot and let it sit for another 5 minutes. It started again and it has been fine ever since. We have only driven it short distances <3 miles since the stall out. I believe it is fuel system related. The car had just over a 1/4 tank when this happened. Could this be as simple as bad fuel? The previous owner said the fuel filter is not that old. Usually when fuel pumps just go out on me I when they go, I can't start the vehicle again, but that has been mostly GM vehicles. Is there a computer module that regulates fuel / air flow in this vehicle? Could that be the problem? There is no check engine light on at this time so I am concerned that if I take this to my mechanic, there will not be any codes coming up to diagnose the problem. I am hoping that one of your technicians has seen this problem with this vehicle and can suggest a solution...I've paid $1800.00 on 2 fuel pumps and computer modules for 2 vehicles in the last year...I'm hoping this won't be the case...thanks in advance for your response
Jul 20, 2008 at 12:05 PM
BMRFIXIT
  • 19,053 POSTS
Symptom of a bad Crank sensor will do that
its located under the distributor on the tranny bell housing
Jul 20, 2008 at 12:58 PM
MISTERENERGY
Is a bad crank sensor common for this car?
Would this show up on a diagnostic even though the "check engine light" never came on?
Jul 21, 2008 at 3:12 AM
BMRFIXIT
  • 19,053 POSTS
yes its a common issue
will not always show up with a code and or check engine light
u can tested with an ohm meter
when hot
Jul 21, 2008 at 9:47 AM
