2000 Chrysler Sebring after about 20 miles the car goes dea
MICHAEL.BORDERS
  • 2000 CHRYSLER SEBRING
  • 6 CYL
  • FWD
  • 138,000 MILES
My car stopped I had a wrecker to tow it to the shop and when I got there it cranked up, I still had a distrubutor assembly put on and drove it home, went to work the next day and had the wrecker to bring it to the shop, it started again, brought it home drove it and it stopped again, they can not seem to find out why it keeps dying out and once it get on the wrecker it cranks up can you help me with this problem
Thursday, September 9th, 2010 AT 4:04 PM
If it refuses to start don't wait for nothing- do below to find out if its fuel or spark problem that's causing it-something has to give.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing.
Thursday, September 9th, 2010 AT 4:09 PM
