1999 Chrysler Sebring Wont start
ILOVETHERESA
  • 1999 CHRYSLER SEBRING
1999 Chrysler Sebring 6 cyl Automatic 150000 miles
everything comes on but it wont start
Sunday, July 25th, 2010 AT 12:02 PM
If its cranking over and will not start. Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Sunday, July 25th, 2010 AT 2:06 PM
