1999 Chrysler Sebring
MJ22HERNANDEZ
  • 1999 CHRYSLER SEBRING
Electrical problem
1999 Chrysler Sebring 6 cyl Automatic
I wanted to know what would my car not want to start? I have already checked the battery, changed the fuel pump, the distributor, the distributor coil, crank sensor, changed the fuses and relays
Friday, August 29th, 2008 AT 8:36 PM
  • 31,937 POSTS
Hi there,
The first thing to do is have a scan to see if you have any set fault codes, also you will have to check foe a good spark, compression, fuel pressure, start here.
Mark (mhpautos)
Saturday, August 30th, 2008 AT 4:12 AM
