Electrical problem
1998 Chrysler Sebring 6 cyl Automatic
Whenever you go to open the door, the built in alarm goes off, regardless if you hit the unlock key pad. Its not the panic alarm, its the horn, it just starts going off but the funny thing is, is that it stops on its own after 10 min...? I try hitting the lock/unlock on the key pad but regardless if its unlocked it goes off, you can even start the car and drive with it going off!
Apr 7, 2009 at 9:44 AM
