Engine Cooling problem
1996 Chrysler Sebring 6 cyl Front Wheel Drive Automatic
The fan is not coming on. How do I determine if its the fan or the relay that isn't functioning?
Thursday, March 11th, 2010 AT 2:29 PM
CARADIODOC
MECHANIC
Unplug the two-wire coolant temperature sensor. That will make the Engine Computer turn the fan on. If the fan doesn't run, unplug its connector and use a test light to check for voltage. If it's there, replace the fan motor.
