It sounds like a weak battery. If the battery is good, then you need to remove the starter and have it bench tested at a parts store. Most will do it for free.
Try jump starting it to see if that takes care of the problem. If it does, have the battery load tested. Again, a parts store will do it.
Let me know what you find.
SPONSORED LINKS
Friday, February 12th, 2010 AT 8:13 PM
