2006 Chrysler Pacifica LIFTERS
2006 CHRYSLER PACIFICA
56,789 MILES • 6 CYL • 4WD • AUTOMATIC
ZAMAIDI
MY CAR IS MAIKING AN HORRIBLE NOISE..MY HUSBAND TOOK IT TO A MECHANIC AND HE TOLD HIM MAYBE WAS THE LIFTERS, BUT HE DOESN'T OPEN NOTHING TO BE SURE..WHAT DO YOU THINK . I WAS CHEKING IN OTHERS SIDES AND I SEE THAT CAR HAVE THIS PROBLEMS, WHAT DO YOU RECOMENDED OR KNOW ABOUT IT?
THANKSFOR YOUR HELP!!!
Feb 16, 2010 at 1:21 AM
ERNEST CLARK
  • 1,730 POSTS
Sorry, but you'll have to describe the noise to me in order for me to help.
Your lifters are hydraulic, and won't make any noise unless they have been starved for oil, or the oil passage inside one/more are clogged. Then the lifters internal cup could sieze in the bore and procuce a ticking sound.
If your's isn't a ticking sound, then it isn't lifters. But if it's coming from the top end of the motor, it could be your cam lobes are exessively worn and producing metalic noise as they push on the lifters/followers.
If you write back with a little more detail, I'll try to help you from there. But any noise coming from inside the engine will require a tear-down. Hopefully, not a complete tear-down.
Mar 1, 2010 at 10:09 PM
WTORRENCE
I too have the same lifter clacking noise that seems to be getting worse. I also noticed several other person s with the same problem. Did you find a solution? The shop where I went stated I have to replace some or all of the lifters at a cost of 2-3k dollars. Why would the lifters go bad. the car only has 50k miles and the noise started at 40k. All services were completed in a timely manor. Ant recommendations? Please post or email me at brasil.will@gmail.com.
Apr 14, 2010 at 12:27 AM
