1993 Chrysler LeBaron TDC Timing
Suggested Repair
Find TDC on cylinder 1 by removing the plug and using a long screwdriver to locate the piston's highest point, bumping the starter and then fine-tuning by turning the crank with a socket and breaker bar. With the engine at TDC, install the distributor so the rotor points to the number 1 terminal position on the cap, then start the engine and refine timing with a timing light.
Conversation Summary
After a head gasket and timing belt reset on a 1993 Chrysler LeBaron 3.0L, the owner could not start the engine to set timing because the distributor mark was made when the engine was not at TDC. The expert explained how to locate number 1 TDC with a screwdriver and crank rotation, then align the distributor rotor with the number 1 cap position. The owner understood the guidance.
