1995 Dodge Dakota Ignition Timing
CHRYSLER
HAYSEED
Greetings to you.
I'm trying to get information on the correct ignition timing for a 1995 Dodge Dakota 2.5L 4 cyl. w/ manual trans.
Should be on sticker in engine compartment, but truck has been repainted and hood may have been replaced. have looked everywhere for it.
Any help would be greatly appreciated.
Thanks.
Hayseed
Jan 12, 2006 at 11:53 AM
  • 110,248 POSTS
17 to 25 degrees BTDC at 2000 RPM's
Mar 11, 2009 at 2:34 PM
Suggested Repair
Set ignition timing to 17 to 25 degrees BTDC at 2000 RPM.
Conversation Summary
The owner requested the correct ignition timing for a 1995 Dodge Dakota 2.5L 4-cylinder with a manual transmission because the underhood sticker was missing after a repaint and possible hood replacement. The expert advised 17 to 25 degrees BTDC at 2000 RPM.
