Chrysler AC Dryer Replacement
CHRYSLER
KENENOON
I was told I need a new condenser for my ac, but 1 mechanic says I have to replace the dryer unit also. but another mechanic says they never replace the dryer unit unless they replace the compressor ( for warranty reasons) he says its reccommended to replace the dryer unit every 3 years but nobody does, its a waste of money. I trying to figure out what to do and not waste money. any ideas?
May 10, 2006 at 8:41 AM
LOSONE
  • 1,616 POSTS
The dryer does exactly what the name implies, it removes moisture from the refrigerant. It also holds refrigerant oil. R0134A inhibits moisture. It is worse than R-12 freon
My rule is to replace the dryer anythime the system is opened to atmosphere. Moisture causes internal A/C issues especially the compressor and reduces cooling efficiency.
There is no rul that i know of after 40 + years as a garage owner to replace the dryer every 3 years except as a sales gimic.
May 10, 2006 at 9:51 AM
Suggested Repair
Replace the receiver/dryer whenever the A/C system is opened to atmosphere, including condenser replacement. Moisture can damage the compressor and reduce cooling. There is no established rule to replace the dryer every three years.
Conversation Summary
The owner was advised to replace the A/C condenser and received conflicting advice about also replacing the dryer. One mechanic said to replace it only with the compressor for warranty reasons and called a three-year interval a waste. The expert recommends replacing the dryer any time the system is opened because it removes moisture and holds oil, and says the three-year interval is not a real rule.
