1998 Other Chrysler Models
ROCKET_BOY28373
  • 1998 CHRYSLER
  • 6 CYL
  • 4WD
  • 161,000 MILES
Got a 1998 jeep sport 4x4 and the brake lights just went out. Its not the bulb its got be in the wiring or the fuse box, I need help never seen this before have any ideas about it? Maybe be a relay?Mayby tell me where the relay is in the fuse?
Monday, September 1st, 2008 AT 7:19 PM
  • 109,885 POSTS
Hi:
Chances are the brake light switch is bad. It is located on the brake pedal lever. Find it and make sure it isn't out of adjustment. If not, make sure you have a power supply coming in, and when the brake pedal is depressed, the power should come out of the other wire going to the brake lights.
Let me know if you run into trouble.
Monday, October 13th, 2008 AT 8:07 PM
