1995 Other Chrysler Models Water Pump
1995 CHRYSLER
187,000 MILES • V8 • 4WD • AUTOMATIC
TMART36
when i put in the radiator fluid into the radiator you can watch some of the fluid come out of the bottom. so i am assuming that its the gasket, but when i got a chilton it makes it look so hard to get to the water pump but when i look at it it doesnt look so hard. The truck never over heats nor does it make noise its just that some of the fluid comes out the bottom. is there another place that i can find a diagram of what to take off so im not driving myself insane
Nov 4, 2008 at 1:53 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:1f3ee8f5c7="tmart36"]Engine Cooling problem
1995 Other Chrysler Models V8 Four Wheel Drive Automatic 187000 miles
when i put in the radiator fluid into the radiator you can watch some of the fluid come out of the bottom. so i am assuming that its the gasket, but when i got a chilton it makes it look so hard to get to the water pump but when i look at it it doesnt look so hard. The truck never over heats nor does it make noise its just that some of the fluid comes out the bottom. is there another place that i can find a diagram of what to take off so im not driving myself insane[/quote:1f3ee8f5c7]
Please post the Model, Sub Model and Engine Size in Liters for the correct diagram
Nov 4, 2008 at 2:12 AM
