Chrysler New Yorker transmission
CHRYSLER NEW YORKER
APHOTICBEAUTY
I have an 89 new yorker, When I got it the dash board flickered intermittantly, When the dashboard does this the car seems to jump and lurch when I come to a stop. I know there are issues with my transmission as well. I just read that the transmission is computer controlled lockup and Computer Controlled Multimode Transmission
could the actual computer be the problem then. or are the transmission issues seperate from the dashboard problems?
Apr 23, 2006 at 8:33 PM
VANDRAGON
  • 298 POSTS
sounds like early converter lockup or clutch pack problems. even the wire to the converter could be bad. take it to a trans shop that gives free quotes or cheap ones.
Apr 24, 2006 at 10:40 AM
APHOTICBEAUTY
[quote:4fb8b8b2ac="vandragon"]sounds like early converter lockup or clutch pack problems. even the wire to the converter could be bad. take it to a trans shop that gives free quotes or cheap ones.[/quote:4fb8b8b2ac]
Thanks I'll do that then!
Apr 25, 2006 at 7:52 PM
