1994 Chrysler New Yorker Caliper Hose Fit
NEON2007
For a 1994 Chrysler New Yorker, I would like to know how do I put the caliper back on the way it was when I took it off. Because , I just had it replaced and for some reason the break plug that connects to the caliper does not want to go back on. Any advice would help me out. Thank You !
Sep 22, 2007 at 8:24 AM
MERLIN2021
  • 17,250 POSTS
I think you are asking "how do I connect the hose to the caliper?" If you have a screw in hose the threads must be the same size...if you have the banjo bolt type, you will have 2 copper washers put 1 new washer on the bolt, put bolt thru the hose, put 2nd washer over the bolt, screw bolt into the caliper...hand tighten!
Sep 22, 2007 at 10:01 AM
Suggested Repair
Match the brake hose connection type. For a screw-in hose, the threads must be the same size. For a banjo-bolt connection, place one new copper washer on the bolt, pass the bolt through the hose, add the second washer, thread it into the caliper, and hand-tighten.
Conversation Summary
The owner of a 1994 Chrysler New Yorker could not reconnect the brake hose fitting to a newly replaced caliper. The expert explained how to identify a screw-in hose versus a banjo-bolt connection and how to install the banjo bolt with two new copper washers, then hand-tighten it.
