Cycle the ignition, just till the dash lites come on, no further. On--off, on--off, on, then the check engine lite starts flashing, you count the flashes to get the codes. Your looking for 2 digit codes. As an example, a code 24 would be two quick flashes, slight pause, 4 quick flashes. Between codes, there should be a longer pause.
Monday, November 16th, 2009 AT 1:31 PM
